Matthew Smith
The push rods were all good and I believe the rocker/rocker arms were good they didn’t seem out of shape and valves and springs were goodWhen you had the heads off did you check for bent or worn push rods, cracked or worn rocker arms, worn rocker arm shaft, broken valve springs or valve installed height?
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build Date: 3 June 2018. Now at 94408 miles.
