Cam the Ram
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
I am looking to get a cam for my 05 5.7 Hemi Ram 1500 QC 4x4
I have stock 3.9? gears front and back. Locker in rear. All internals are stock.
Airraid CAI & Filter, Hi FLow Magnaflow Cats, Maganaflow ****. Shorty wires, Diablosport Trinity 93 Tune.
I want the most power I can get with the stock stuff, I know to do the pushrods and springs with the cam. Only future mods planned are 4.58 gears front and rear and a better Torque Converter. I rarely tow anything if I do its a small trailer less that 2000lbs. I dont care about lope(I Like It). I want power from TC lock till about 6000 if possible. Any sugestions or Questions feel free!!!
Thanks for your help!
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Any plans for a track? Comp 260 and 268 are the top list that people have alot of luck with. Inertia makes a few also and can taylor a cam to.what you want out of it.
truckin151
2013 sport
The 268 in a QC 4x4 I don't think would be a good idea. Its not a tq cam by anymeans down low where he would need it
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Great Subject/Thread! I cannot offer the same good advice as Ryan or Kenneth so Joshua you are in good hands with these Guys. Now if you had an 03 Forgottens Ram I could offer up some good mod Ideas.
Joshwaa
Joshwaa
Lake Worth, FL
Thanks to all for responding. OK i dont drive the truck to much so I dont mind making it wild. I want tho get the most out of the truck. From what I understand I can do a cam and TC and be pretty good with what I have done already. However I would like to run a 13.10 1/4mile time. So if heads are needed I could see doing that. The truck from the Trinity race thingy says my 0-60 time is 6.6 if that helps. I have not made a run at the track since I put the other parts on and lightened the truck.
Joshwaa
Joshwaa
Lake Worth, FL
Truckin151 I keep thinking about what ur saying about torque. From when I used to build motors it was for my firebirds at the track. Which was usually big roller cams, hogged out heads and no need for torque. But I think I would like to get the most torque possible I like the idea of having the ability to start spinning the tires at a 20mph roll rather than waiting for the motor to build up to the high end HP. Hope that gives some better direction.
RubberFrog
Comp 260 or a sidewinder. They're great torque monsters for these trucks.
Joshwaa
Joshwaa
Lake Worth, FL
Thanks Frog. What do you run in yours. Will it spin those 37" nittos?
Joshwaa
Joshwaa
Lake Worth, FL
BTW a comp 260. Can you translate that to s summit part number or something. I see way to many listed for my truck.
EJM05
Somers, CT
440 Big Block
Contact our vendor. He may carry them or get you them for the same.price or lower.
Joshwaa
Joshwaa
Lake Worth, FL
Thanks EJM05. What vendor? Also nice truck.
Also another question for the forum. I see a lot of ppl use the 6.1 springs and pushrods? Are they the best to use? Also any good aftermarket roller lifters or are the stock set ok?
RubberFrog
I'm running a sidewinder variant. Supposedly it has slightly more torque than a sidewinder. Short of dynoing a sidewinder in my truck and them dynoing my cam, I dint know how to verify that. lol. I do know it has WAY more torque than stock.
I can't spin the 37s but I can spin my 35s when the weather is right (i.e. cold winter).
truckin151
2013 sport
If you want to go bigger, id say a spartan cam or a 210x if you can find one both of those need tuning to run right though. The 260 and sidewinder don't need anything more than a canned tune. So it really all depends on how much you want to spend
HemiSwapped06
Euless, Texas
imo you want to have less spin when you put in a torquey cam.
The low-end torque cams just anhilate the tires if you stand on them from a stop. My first gear is worthless if I hammer on it on the street.
Sidewinder
Joshwaa
Joshwaa
Lake Worth, FL
Thanks so much for all your help. Yea I found the thread with all the diffrent cams being run. I do not care if I have to get away from a canned tune to run a cam. Not a problem. My main thing is I don't want to have to go from cam to cam. I would like to put the most power in. If I need heads to do it right I am ok with that. I just want the most power I can sqeeze from my Hemi.
Joshwaa
Joshwaa
Lake Worth, FL
So if I don't mind having a tune written for my truck what is the most powerful cam I can put in with the stock heads. Also could I put in a converter to match the cam? Possible?
stevenmicheal
