The cam/lifter problems didn't seem to start until the redesign in 2009 with 2011 being the most popular year. More than likely your tick is from broken exhaust manifold bolts which is common in all 5.7 HEMI's regardless of age. If the tick goes away in less than 10 seconds its an oil related tick. If it takes like a minute or more then its most likely broken bolts. If you're not already running 5W30 I would switch to that at a minimum to help with valvetrain noise.What year did Dodge start having the hemi tick along with the cam and lifter failure.
If the MDS is active it calls for 5W20. Deviating from that can cause system errors. If MDS has been disabled then 5W30 is perfect.
How do you deactivate the MDS?
How can I tell if mds is active or inactive on my truck? bought it usedGet a tuner
Been using 5w30 PUP for 24,000 miles. No problems yet. MDS not disabled. 5.7 engine, annual or 7,500 mile oci. 50,000 mi on engine.If the MDS is active it calls for 5W20. Deviating from that can cause system errors. If MDS has been disabled then 5W30 is perfect.
