- Jul 12, 2021
- 59
- 70
- Location
- South Central PA
- 2020
- Hemi 6.4
1) antenna cable can easily be run along the trucks frame
2) slide yourself just in front of rear tires, you will notice a few rubber plugs in the Floor Pan, in fact you can cut new holes & buy rubber plugs from places like NAPA
3) when you open any door, there is a strip of rubber, plastic, or aluminum that protects the Door Sill.
Under those door strips, there is already hidden wiring & room for more, especially on the passenger side of the truck
4) don't just cut through the carpeting, because there are more wires under there, like for the drivers seat motors, the OEM 115 V inverter is either mounted on the front passenger seat frame or on top of the drive shaft hump
Thanks for the info. I'm very familiar with how wiring is routed in the cabin. I've had most of the interior of my Jeep taken out and I would guess the Rams are similar. I suppose that I'll have to go exploring because I'm not sure how the wiring from the bed is routed to the cabin -- and it has to be routed somehow because tailgate goodies (backup cam, remote release), bed lighting, 4 and 7 pin harnesses, and tail lights. I suppose I'll have to chase down the wires and route similarly.
But that still leaves the installation of the CB in the cabin -- still looking for a non-hack solution.
