Cant find my radio antenna....
kaferhaus
Mobile, Alabama
5.9 Cummins
2005 3500. Old radio not working (ever since I bought the truck a couple weeks back. Went to replace the radio and can't find the antenna cable.... any hints???
HemiLonestar
MD
If it isn't right there you may have to fish for it. If the truck got screwed with someone may have cut it and it may not be there at all.
tron67j
Maryland
Take the antenna off and see if the cable is still attached to it. Then you can run a wire pull to fish it back. Good luck
Treburkulosis
Your High End Detailer
Haslet, TX
I accidentally dropped mine in the fender. I was able to remove the wheel wale slightly and had my kiddo help me fish it up and back into the fender. It was a 10 minute fix.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I am surprised that you cant gently remove the right side Kick Panel
There should be access panels behind it
If i were younger, i would be pulling the glove compartments just to check things out
lasse452
