JohnnyOOO
I'm have a clicking type noise(see attached video) coming from under front end of my truck. It goes away when I slip the vehicle into neutral, happens in 2WD and 4WD, probably at all speeds but easier to hear at lower speeds. I did have a check 4WD code a month back but no codes are presenting currently when run diagnostics.
My local wrench is trying to correctly diagnose put his noise isolating device on the transfer case and does not think it is a gear grinding issue, do not want to replace transfer case if that is not the problem. He said it sound more like and electric motor trying to shift but not executing. He thought it was a good idea to ask your thoughts.
Thank you in advance for you comments and knowledge.
Noise video
Noise video
