I never throw anything away,lol .An old piece of plywood cut into strips glued and screwed together,and some homemade "L" brackets made out of scrap flat bar. They're 12 years old now,and starting to show their age,but it keeps the ramps from sliding on concrete and are long enough the front spoiler on a Challenger clears the ramps when using them on the front.Simple Yet extremely functional
@JHoward these are the ramps i was telling you about that i'd modified so the wifes last 2 Challengers and our 300 will drive up on.
The bottom board is roughly 25" long,and the whole length of them is just a bit over 37" Nick.Thats genius! I may have to copy that. 2 out of our 3 Mustangs are too low for ramps. How long is the longest board?
The part that concerns me is why are our dodges always up on ramps?I never throw anything away,lol .An old piece of plywood cut into strips glued and screwed together,and some homemade "L" brackets made out of scrap flat bar. They're 12 years old now,and starting to show their age,but it keeps the ramps from sliding on concrete and are long enough the front spoiler on a Challenger clears the ramps when using them on the front.
I'm way to cheap to buy a set of Race Ramps![]()
It's not because we drive them hard haha.
Those are cool. I need a good lift. Been doing too much on the floor these days.There's always one of these for a low roofed home garage.
QuickJack Models - Portable Car Lifts - Car Lifts
QuickJack portable car lifts are the perfect addition to your garage or auto shop. QuickJack car lifts are convenient, quick, and very safe.quickjack.com
My neighbour has one,and it goes under his Vette with no problems.I borrowed it once to try out,and they're the cats-ass for doing tires / brakes / oil changes etc.,the only downside is the limited side accessThose are cool. I need a good lift. Been doing too much on the floor these days.
The couple i've looked at,all have a locking bar.Do they have some sort of mechanical safety lock?
My next house will have a full-sized lift, if that fantasy works out but otherwise, I'd like one of these.
Thank you, thats very helpful.The bottom board is roughly 25" long,and the whole length of them is just a bit over 37" Nick.
You could make them any length you wanted though.
I prefer to use 3/4" plywood for the bottom board,so it's easy to drive up on,after that you could use 2X6's if you wanted.Once the tires are on the bottom board it won't slide away,so if you wanted to use 2X6's instead of plywood for the steps you could.I had an old scrap piece of 3/4" plywood laying around,that was more in the way then anything,and was to rough to use for anything but a set of ramps,so it's what i used.
The L brackets latch into the old ramps i have,and keeps them locked in place so the ramps don't slide on concrete,if your ramps aren't like my old ramps,you might have to come up with another way to latch them together,but a latch screwed on the side of the ramps or boards that swings over a bolt or screw on the connecting part would be easy enough to fab up,and would still be easy to work with,and you'd still be able to remove the wood section,so it'd be easy to slide under the vehicle
I have these and love them. I still like to use ramps for some jobs but the quick jacks are a great option when you dont have room for a real lift. They are super stable to, I feel much safer working under the car on these than I do jack stands.There's always one of these for a low roofed home garage.
