Catch can
ltr450rider13
Can someone show me where your mounting catch can? Maybe on a 2500. If possible. I got one same as billet technologies and can't mount. Have included pic. Bracket will hit sensor if mount to bolt to right in pic.
ReturnToSender
Caledon,On,Canada
Hemi 5.7,QC 1500 Big Horn
Hmmm
It all most looks like the bracket is backwards ,
I dont have a catch can so i'm no professional but can you remove the bracket from the can and turn it around ?
1500ram12
5.9L Cummins
Down and to the left their is 2 wholes the top one is the one you want
Sent from my DROID RAZR MAXX using Tapatalk
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
Move it over to the passenger side head. The position in the picture is to far up, and over. If you look on the front of the passenger side head you will see to empty threaded holes....use them. 1500ram12 has some nice pics he posted just the other day on his install.
2012 R/T Joe
South Jersey
In your first pic you can see the freeze plug in the head just below your catch can. The suggested spot is up and to the right where the wire loom is affixed to the head. I used the one to the left and down from the freeze plug.
ltr450rider13
ltr450rider13
Got it. Thanks guys. FYI can came from eBay upr productions cheaper then BT and same thing. ImageUploadedByTapatalk1358462210.588588.jpg
WilCon76
MD
2013 Express 2WD
I bought the same one. The BT can drains differently. It unscrews the bottom leaving a cup for the oil. The UPR one you can remove the bottom or unscrew the drain plug in the bottom and empty it. Not quite as user friendly.
DUCKY1090
