Cd player won't take disc.
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
I have an 06 with 6 disc changer today I went to change discs and it wasn't switching them and it would eject them. It did it to all 6 discs. Now when I try to put a disc in it sucks it in and out multiple times then it just ejects it. Any ideas on this or is it just shot? Radio still works.
autokraftgt
Hemi 6.1
Things like this wear out in due time...prob time to replace
wiram
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
That's what I figured. It is 8 years old. What's a good stereo to put in as a replacement?
EOD_Tex
Central Arkansas
2014 Outdoorsman 4x4
Those changers are pretty notorious for breaking. Did in my 07 also. I replaced it with a Pioneer in-dash NAV unit. Loved it.
wiram
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
What all did you have to do to change over to the pioneer and which one was it
EOD_Tex
Central Arkansas
I meant to say Kenwood. Pioneer was in my first Ram. I changed over to the Kenwood DNX771HD. The reason I chose kenwood over Pioneer is that Kenwood uses Garmin maps, and you can ground the unit to get around video/gps input restrictions with it--the Pioneer is harder to defeat. Anyways, if you've got a stock, standard radio, you will need to modify your bezel, or get the bezel made for the factory nav unit so it will fit. You'll need a dash instal kit either way, as well as the wiring harness. It was pretty striaghtforward, I followed the directions and it went well.
If you need a bezel for a Gen 3, I have one.
wiram
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
Found a Kenwood double din with all the mounting stuff for about $400 installed.
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
I think this is happening to a lot of us with the CD decks. Things wear out and that is most likely what is happening. I replaced mine with a Kentwood headunit that has the USB input and have as of yet to stick a single CD into it. My usb dongle holds all the music I need and want to listen too.
wiram
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
I ended up paying 503 installed with a 4 year warranty. That's probably what I'll use most of of the time but it's still nice to have a working cd player.
EOD_Tex
Central Arkansas
Nice! the warranty is maybe the best part of that. Good to hear you're back up and running
