center console squeak
rblochli
NJ
2024 Limited
Hemi 5.7 eTorque
I have a squeak that is driving me nuts coming from the center console. If I jam my hand in by the 12v plug it stops, I want to remove the console and see what is causing it. I've read that the chrome trim ring pulls up - how many screws hold the center piece in? I saw a screw under the rubber piece by the 12v plug, I'm assuming some are under the cup holders? Anyhing near the shifter?
Thanks,
Bob
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
Do you have anything in the cup holders? I found times when I have certain containers in the cup holders it makes a noise that sounds like it is coming the console itself. if I hold or remove the bottle squeak is gone. Found same thing with the pull out storage drawl in the dash. If not closed all the way creates a squeak.
bendirkss
Canada
If it's a center console shift, that big console under the little one has 4 little rubbers keeping the big lid from hitting when you close it. On mine they wore out so I put weather stripping there to separate it and haven't heard a noise since.
rblochli
rblochli
NJ
2024 Limited
Hemi 5.7 eTorque
nothing in the cupholders or any of the others spaces. It's a plastic crackily noise (if that's something) If I put my fist in the compartment next to the shifter (12v in front) I can get the noise to stop.
