MedicWill
- May 9, 2016
- 29
- 28
- 2016
- Hemi 6.4
I added Centramatic wheel balancers to my stock Wagon on 37s.
Smooth as butter!
Smooth as butter!
It is a disk that bolts on with your wheel. If you drive on rocks a lot you know that they stay stuck in the tire tread for a while and cause vibration. Or if you off road you tear off a chunk of tire, then these are helpful. They are about 6oz of sand or a liquid that moves freely and is to balance out the tire again. It is very popular in semi trucks. But Jeeps use them a lot too.What are centramatic balancers?
Their website boast that they save 25% tire tread and some gas but no explanations how.
I looked up some videos but I just don't get it ( and is it an older version of the shamwow salesman?! ).
Educate me!
What was the part number on the ones you chose?I added Centramatic wheel balancers to my stock Wagon on 37s.
Smooth as butter!
Did you pull the regular wheel balance weights and use the centramtic as a “replacement” or do you run both?I added Centramatic wheel balancers to my stock Wagon on 37s.
Smooth as butter!
Centramatic recommends to use both, which I did.Did you pull the regular wheel balance weights and use the centramtic as a “replacement” or do you run both?
OA
Educate me!
Smooth as butter!
Were you getting lots of vibration before installing these?
