KKBB
This morning I washed the truck, used iron remover but didn't see anything except for on the rotors when I sprayed the wheel area, so I skipped that step. Then, clay mitt. After that I dried the truck and started to polish it for my first time ever. It went well. I then used some IPA solution from Adam's to clean the polish oils off the truck. Then I started to use Adam's graphene ceramic coating...I am about half done with the truck and it started getting dark and my back is done so I called it quits for the night. I will finish tomorrow. Everything I used is Adam's products and so far all has been great. The only issue I had was cleaning the hood with the IPA I scratched it in a couple spots because my garage isn't big enough to work in so I had half the truck outside and must have gotten some dust on the hood and didn't notice when I wiped it down and put a couple scratches in it. I will have to touch up with the polisher in the am.
