Check Engine Light!!!
woojyee
Nebraska
Hemi 5.7 eTorque
Welp, spent the day installing my new JL Audio gear, got everything wired up via the speaker level inputs. Sounds great but now the frigging Check engine light will not shut off!!! Any ideas?
jwheeler
Washington
First idea would be pull codes. Can't do anything before that.
woojyee
woojyee
Nebraska
Hemi 5.7 eTorque
What code are you getting?
The shifter plug wasn't in all the way it turns out.... But the light is still on. Will it reset if I take the neg battery cable off for a bit? I really don't want to buy a code scanner :(
Etroze86
Grand Forks ND
Go to a parts store use their code reader pull the code then erase it and see if it comes back.
woojyee
woojyee
Nebraska
Hemi 5.7 eTorque
Oh yeah.. good idea... thanks :D
But what would be a decent reader to get if I decided to get one?
Etroze86
Grand Forks ND
Well if you tune your truck a tuner can pull codes. I've had the innova brand from O'Reillys and they work really well.
Etroze86
Grand Forks ND
Oh yeah if all you need to do is read and clear codes its perfect.
7777xm
Covington, GA
It should clear itself after 3 or 4 successful start and run cycles without the error.
Sent from my Nexus 6 using Tapatalk
