Check me before pulling trigger on wheels
El_Dude
Spring, TX
2019 Classic SLT
Tirerack.com seems to find the best selection/price so I will most likely go with them.
Rims:
Granite Alloy GA641
18x9 Black painted- Offset: +12mm
5x139mm
Tires:
Toyo Open Country A/T III
35X12.5R18LT
Load Range: D
Serv. Desc: 118R
mount/balance
new tpms sensors
warranty
Total: $2,402.09
How good are black pained wheels? Would I have to worry about any peeling? Are the Toyo's reasonably quiet?
Treburkulosis
Your High End Detailer
Haslet, TX
It all depends on how well you take care of wheels. I would suggest ceramic coating your wheels to insure protection. I have Open Country R/T tires and they have some noise, but honestly not that bad. My Nittos were a lot louder.
El_Dude
El_Dude
Spring, TX
2019 Classic SLT
Wheels and tires are like women .... No one can pick them for you ... period .... no argument ....
Of course there's no argument. My post is for checking that it sounds like a good fit technically, not a stylistic opinion. Customizing a car is new to me and I'm trying to make sure I get the right parts. Thanks for you post, anyway.
El_Dude
El_Dude
Spring, TX
2019 Classic SLT
Thanks Tre.
crazykid1994
+12 offset may be tight on that upper control arm with 35s. I have -12 offset and 35s and have about 1” of a bit more clearance. Not exactly sure on my clearance since I haven’t measured it. This is the best picture I could find. Hard to tell my clearance from a picture.
El_Dude
El_Dude
Spring, TX
2019 Classic SLT
Thanks crazykid.
Man yea, that looks close. Also I have a Maxtrac 4.5 lift kit that is sitting in my garage, waiting to be installed. This is what it says on their page on their kit.
  • Track width increase of 1" per side
  • MAXTRAC SUSPENSION DOES NOT ADVISE USING WHEELS WIDER THAN 9" OR WHEELS WITH LESS THAN 4.5" BACKSPACING
I'll check the backspacing on the wheels..
VelocityC6Z
Maryland
You need at least -12 offset to get you the backspacing to clear the knuckle.
I have -12 with 37x12.5 on my 17" wheels and there is about 3/4" between my tire and control arm. +12 will rub, 0 will rub. -12 is as close as I want to be lol... I partially want to go back to looking at wheels now to find something closer to -22 to -24 just to give a little bit of space up there.
El_Dude
El_Dude
Spring, TX
2019 Classic SLT
What is your rim width?
co-pilot
houston,tx
Is your truck 2wd or 4wd?
The 18" wheels might not work
And I agree with all ....at least -12 os
El_Dude
El_Dude
Spring, TX
2019 Classic SLT
2wd
Sent from my OnePlus 8 using Tapatalk
El_Dude
El_Dude
Spring, TX
2019 Classic SLT
I appreciate all you guys input. I will be doing some more homework on this just in case.
co-pilot
houston,tx
2wd
Ok....you might want to check the details on your lift.....I know your said it was Max Trax .....but on my Rough Country 4" 2wd ...it says " will not work with 18" wheels "
Hope this helps....
