Check your air filters
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
I checked mine yesterday and it sill looks pretty good but I went ahead and ordered a MOPAR one for when I need it.
Anyone change out their cabin air filter....it's interesting that the interval for the cabin air filter is every 20K miles but the engine air filter is every 30K miles (earlier if required).
Dang mine is needed already then too. I’m slacking on maintenance.
donivan
Houston
A couple maintenance items that I"m not used to are lubing the front drive shaft every oil change and lubing door hinge roller pivot joints twice a year...never done that on any car.
I got some maintenance goodies in the mail this week...air filter, engine oil, oil filter and gear oil.
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
In case you’re wondering, this is what an air filter looks like after you drive through muddy water and hydro-lock your engine lol
LeesEvoX
Houston, TX
Hemi 6.4l
That actually looks pretty clean... but then again, i guess thats what caused your problem. After something like you did. A clean filter = a dirty engine! XD HAHAHA
Bahn112
Los Angeles
HEMI 6.4L
I thought I had read somewhere that the +19-20's didn't have that lube point on the front driveshaft. Perhaps i'm mistaken.
I took a look in the manual for my '19 and saw the door hinge roller lube but didn't see anything about the driveshaft.
turkeybird56
Central Texas
The 1500's do not have the lube pin, the 2500's do, to my knowledge...
Breaker Alex
Breaker Alex
Gatineau, QC, Canada
2019 Power Wagon
Just curious about the old filer in the pic. Also wondering if it will fit the 2018 6.4 air box! I have a 2018 PW, when I went looking for a new filter, the WIX, Microgard and Purolator that crossed over and listed by application were about 1/2" "shorter" than the OEM 68190705AA which was factory installed. I bought the Fram CA 11960 from Amazon which measured the same as my OEM ! If you could give me the number from your "old" one or replacement, I will see if it will fit my truck. When it comes to air filters more is always better!!
It's not the same filter.
2019 and up HD trucks with the 6.4 hemi got the 6.7 Cummins air box.
So I got the Wix 46930. It fits 2007 to 2020 Ram HD with 6.7 Cummins AND 2019 and up Ram HD 6.4 Hemi.
https://www.wixfilters.com/Lookup/PartDetails.aspx?Part=128559
As you could see in my post, I bought the wrong filter ( one that fits your 2018 ) and gave it to my cousin :doh2:
scott lass 18
rocklin ca
2010 ram 1500
did a volant set up foundly got a new filter replace after 10 years and its washable very easy to clean each year !
IRSmart
Westminster, MD
2018 Power Wagon
6.4L Hemi
No, the giant water obstacle I drove through at high speeds was my problem. Probably cleaned my air filter out a bit lol
Bahn112
Los Angeles
HEMI 6.4L
Found the thread in one of the Powerwagon FB groups. Basically stating that the +19-20 changed from the double cardon joint to a rzeppa joint and thus does not have a service interval (as there is no grease fitting there).
LeesEvoX
Houston, TX
Hemi 6.4l
Wait so 2019-2020 PW does NOT have the grease fitting?
Sent from my SM-G950U using Tapatalk
Bahn112
Los Angeles
HEMI 6.4L
This is just what I read. I haven't crawled under there to check yet as I only have 2,000 miles on my truck.
donivan
Houston
Just checked my 2019 manual and that inspection is not in there for the gas engine but it is for the Diesel engine. Diesel definitely has a few more items to maintain!
LeesEvoX
Houston, TX
Hemi 6.4l
So just checked my air filter.... I might be in the honey business soon! Look at all those beeees!
Also found a nice 2" nail in my rear tire. Which I'm glad I found now, rather than half way to port arthur tomorrow... FML693f20166b1698871af3900faad2bbd4.jpgf563f9eb4a8629aa0dfc6c676877c5a0.jpg
LeesEvoX
Houston, TX
Hemi 6.4l
Oh, and someone please tell me I got ripped off at the o reillys... $50 bucks for a damn wix filter!
donivan
Houston
Seems high....paid $29 for OEM and the Wix was even cheaper than that on Amazon.
LeesEvoX
Houston, TX
Hemi 6.4l
I'll check amazon out next time then. Couldnt believe it when she said 50 bucks
