Chips
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
gonna want programmer not a chip
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
A chip is an item (basically a circuit board) that is plugged into the wiring harness between the PCM and the rest of the engine. It's functions are very limited and basically, they tell the PCM that the engine is running lean and the PCM adds fuel to compensate. It's a very poor way to make a little bit more power.
To make a distinction today between a tuner and a programmer is almost impossible. However, previous generations of tuners had canned programs and that was it. You couldn't update them and your selection options were very limited, including tire size, shift firmness, speed limiter removal and, in some cases, raising the rev limiter.
Today's tuner aka programmer, have canned tunes + the ability to hold multiple tunes and you have a lot more program options available to you now. Some of those options are adding or reducing fuel, shift firmness in stages, adjusting knock retard, timing, different gear sets, yadda yadda yadda.
mct601
Mississippi
5.7L
Superchips? Isn't that the one on Youtube with shifting issues?
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Sc 3815 stacked with sct and rocking clean and true at 125k ....
Does not help since I realized this is th 4g section.
Sent from my SCH-I405 using Tapatalk
MADDOG
Living in a Firepit
6.4L HEMI
DiabloSport Predator would be my suggestion. I have two MOPAR vehicles with HEMI's in them and both have a Predator loaded on them. Here's my truck dyno sheet showing before and after Predator install numbers.
The MegaCan runs a lot better and with the addition of an intake and exhaust, I've seen almost a 4 MPG improvement in highway mileage.
The other vehicle has the aforementioned Predator + a DiabloSport CMR tune stacked on top of that. Here's a gratuitous pic of that mod ho:
With the CMR tune, done by a DiabloSport authorized and trained tuning shop, my SRT (stock rated 425 HP @ the crank) put out 411.4 RWHP after the tuning was completed.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
From my post above
B
BigB55
The Woodlands, TX
Ya but the tuners are way out of my price range
and i'm not looking so much for power but fuel efficiency without sacrificing a whole lot. would it be worth the chip temporarily until i can get a tuner?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I think they would do more harm than good. Just save up for a tuner, might even be able to find a used one as they come up for sale on the forums, and ebay.
TheSatinPumpkin
2004 Dodge Ram
5.7L
Save your money or buy some Doritos for your chip fix.
Hemi Joe
Berks County, PA
What does the dealer think about the programmers if you have to take your truck in for warranty work? Is the programmer something you have to leave in the truck for it to work or do you just upload tunes to the ECU and remove it?
biggin152
Are there programmers avilable for the 4th gens now?
quietpeen
2021 TRX
Hellcat
your best bet is to return your truck to stock before taking to dealer. If they find that its tuned they might flash it on you then you are stuck with a tuner that won't work.
mikep345
