Help Support Ram Forum by donating:
Chris's 6.4 Hemi Stroker Truck
Discussion in 'Member Trucks' started by chrisp2493, Oct 30, 2016.
  1. Ian_Olivas
    Ian_Olivas Senior Member
    21
    270
    48
    Oct 19, 2016
    San Antonio,Tx
    Ram Year:
    2002
    Engine:
    4.7L Magnum
    How is that efan treating you? Any problems? Temperatures stay about the same as the stock fan?
  2. Johnnymac2k6
    Johnnymac2k6 Senior Member
    902
    507
    Oct 5, 2016
    Ohio
    Ram Year:
    2007 Ram 1500
    Engine:
    this is looking really good. Im gonna have to catchup on all you've done to it!!
  3. chrisp2493
    chrisp2493 Always Modding
    25
    2,999
    1,840
    Oct 30, 2016
    Warren, OH
    Ram Year:
    2003
    Engine:
    392 Hemi
    I had a bunch of issues to work out with all the changes I did to the coolant. Got stuck with two bad thermostats in a row that made the truck over heat, had a coolant hose slip off while driving and short out the efan one day. After I got all the bugs worked out it’s running fine. Hottest it gets is around 195°.
    Ian_Olivas and HemiLonestar like this.
  4. chrisp2493
    25
    2,999
    1,840
    Oct 30, 2016
    Warren, OH
    Ram Year:
    2003
    Engine:
    392 Hemi
    Polished Eagle heads, Eagle truck manifold, new headers and Custom built Y pipe, reflashed the converter to 3400, sent the valvebody back twice in the past 3 months to get converter lockup issues fixed. This year has been rough with a ton of stupid issues and breakdowns unfortunately. Right now it’s back to running fairly smooth
  5. Johnnymac2k6
    902
    507
    Oct 5, 2016
    Ohio
    Ram Year:
    2007 Ram 1500
    Engine:
    how are you activating the active runner? had it to the track yet!?
  6. chrisp2493
    25
    2,999
    1,840
    Oct 30, 2016
    Warren, OH
    Ram Year:
    2003
    Engine:
    392 Hemi
    I have an MSD window switch hooked up, but after I got it all together I found out the solenoid on the intake was broken and I never got around to ordering a new one since I was having so many other things breaking on me at the same time. I haven’t been to the track yet, I just got the transmission working right last week
  7. Ian_Olivas
    21
    270
    48
    Oct 19, 2016
    San Antonio,Tx
    Ram Year:
    2002
    Engine:
    4.7L Magnum
    Couple questions. What did you do to up the fuel pressure. I went through this thread again and you talked about swapping to an 05 pump and walbro 255 or an external regulator, which route did you go? Also with the fuel rail you have feed lines going to both sides of the rail even though they are connected through a center line, what's that purpose? Is it like a "return line" just keeping the fuel cycling?
  8. chrisp2493
    25
    2,999
    1,840
    Oct 30, 2016
    Warren, OH
    Ram Year:
    2003
    Engine:
    392 Hemi
    I just replaced the 2003 regulator with a 2005 regulator. I added a fuel pressure gauge at the fuel rail and can confirm it has 58 psi of pressure. I haven’t changed out to a better pump yet, haven’t really needed to quite yet. I added the extra hose so it had better flow to the other side of the fuel rail because that crossover was kinda small, I have no idea if it helped or not. I switched back to the normal single attachment with the new intake manifold I’m using
    Ian_Olivas likes this.
Share This Page
