Chrysler Combustion Cleaner
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Anyone try this out?
http://www.amazon.com/Genuine-Chrysler-Accessories-4318001AD-Combustion/dp/B00BV4D97K
I have no pinging but figured while I'm doing other maintenance
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Supposed to work good. But the last time I heard of anyone using it was about 5 years ago. :D
Stegs
1998 Dodge Ram 1500 4x4
5.2L 318 C.I.
jsmith
I've used it on a few different vehicles and like it better than Seafoam. It has been a few years though as dealer I used to get it from quit carrying it so thanks for the link!
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
No problem!
is this stuff used the same way as seafoam? I thought you just sprayed some in the intake
/throttle body opening?
You guys spray the whole can or just a little bit?
Stegs
5.2L 318 C.I.
No problem!
its been a while since i used it but i think i poured it very slowly right thru the throttle body....maybe half that way, the other thru the break booster line
jsmith
No problem!
This is an aerosol foam so you just spray it down the throttle body while keeping your truck idling. I've always used the whole can. Then kill the truck, let it sit for hour or so and take it out on the highway for a drive being sure to hit wot a couple times and you're done
RAM-it83
