Clayton 2.5 Coil Springs fit the back of the 5th gen RAM 1500
ram1500rsm
Trabuco Canyon, CA
They fit 4th gen 1500 (i'm running them myself) and just verified they also fit the DT 1500 trucks. They'll provide 1.5" on top of the ORP/Rebel rear coils. should be 2.5" on non ORP.
Clayton part# COR-1510251 ,This are made for the 2020 Jeep Gladiator but happen to fit our trucks. FCA shared the 4th gen 1500 rear control arms and panhard with the Jeep Gladiator, so the Jeep aftermarket being the Jeep aftermarket happens to improve what the factory did and so in this case these things are perfect for overlanding/expedition tasks
Stock ORP coil rates seem to be around 220 ft/inch and have 20.25" free lenght.
Claytons have 21.5" free lenght, and have 3 rates (progressive coils). Truck drives like stock but she sag less under weight and can support 29-29.5" extended shocks in our application
  • Spring Rate 1 = 159 lbs/in
  • Spring Rate 2 = 280 lbs/in
  • Spring Rate 3 = 360 lbs/in
You can run the OE Fox 2.5 rear shocks for the 5th gen RAM with this coils. Fox 2.5 883-26-079, 25.65" extended, 16.85" compressed.
Jt 2247
Saginaw Michigan
Hi I have a 2017 ram rebel my air suspension has broke and I want to change over to coil overs. I was thinking about getting bilstein 6112 struts for the front and clayton 2.5 coils for the rear. What else do you think I would need? I don't want to modify the truck it's my daily driver and I don't do any off road stuff. Just a little lift and no sagging thanks for your time and help in appreciate it.
JoeCo
NY
Sorry I can't help, but you may want to make a post in the 4th gen section to ask your question. This is the 5th gen section for 2019+ rams and this thread in particular didn't seem to gain any traction from when it was started over a year ago.
Welcome to the forum and good luck!
