Awesome, thanks!Yep both. I’m running the full set.
Is the panhard/track bar on there site that's listed for the 2020 Gladiator also fit our trucks? I'm thinking it will? But want to make sure. Ours is flimsy.
Cheers!
Awesome, thanks!
Cheers!
Yep it shout fit, COR-4510110Awesome, thanks!
Cheers!
It centers your rear axel and prevent your axel moving side to side.What does the panhard/track bar do? Does it help if you are lifted?
If you have a lift kit that reuses the stock bar you should be fine set to stock length. Only reason otherwise would be using parts to lift that don’t readjust the stock track barOn the lca I matched oem to new Claytons (as shown in pic on original post). On the track bar, I assume you don't do it this way since my rear is lifted? Do I adjust to fit per say?
This should give you the idea. Same concept and you can measure the same.I have the lifted coils and spacer. I am guessing 1.5" lift in the rear.
Yep, that's the one.Is this the correct set of uppers and lowers for our trucks....
https://www.claytonoffroad.com/product/jeep-gladiator-overland-short-rear-control-arm-kit-2020-jt
My Core4x4 rear links are supposed to show up tomorrow. wooo WooooNice! Can't wait for mine to show up.
I just added the core sway bar end links in the rear and that made a noticeable difference in stability. I would recommend those as well.
I love mine. Only issue I had was the grease fitting would have hit the bracket so I mounted it to the outside of the bracket instead of inside like stock. Also pulled them apart to grease them better before install and used red moly grease Which is better for poly bushings.My Core4x4 rear links are supposed to show up tomorrow. wooo Woooo
