RAM08110719
- Nov 8, 2019
- 84
- 55
- Location
- marseilles Illinois
- 2008
- 4.7 L V8 E85
Ok. Tech terms not well known here. But the problem is. The I think lifters. Metal straws that deliver oil to top of crank case. My straws are sludged. Most is gone. After using the much needed synthetic oil. Still not clean. I did utube research. Found high miles version of seafoam oil additive. So I take out oil put some in run it for 150 miles. Then change oil. This they say cleans the lifter sludge. Besides popping the top of the engine. Doing this as a break down manual job. Is this an effective route? I also have the can to spray into the engine. I would think that kind of cleaning would be needed after the fact. Is their any other options to make this clean and right again? Or am I on the least invassive path to a clean engine.
Besides those lifter sounds. It runs great at 121k miles.
Side note. Very strong and well built truck. If there is more I can do. Or a better chemical I could use. Please? Want to get more than 4 years out of my truck. Any ideas other than this that include chemicals only. Don't want to open the engine. Thank you.
