Clever rear seat organizer for Quad Cab needed
PedalToTheMetal
Novi, MI USA
5.7L HEMI
Hi,
I am always hauling a ton of brochures, folders, samples, small tools, etc. around with me.
I used to have everything in an organizer and a file storage box in the trunk but now replaced my SUV with a RAM 1500 Quad Cab.
It has the rear seat folding platform. With it folded down, there however don't seem to be any good attachment points available. The other thing is, that whatever is laying on the platform, goes flying the first time I have to brake or make a turn, as it doesn't have a lip around it.
Anyways, I am looking for some clever ideas of how to organize my truck's rear seat area and to keep things in place.
The 'best' thing I have come up with so far is make a wooden box, with an open top and covered with carpet, and to bolt it to the folding platform.
I don't need the rear seats, whatever I install can therefore be semi-permanent, as long as it is reversible, if I ever want to sell the truck.
What are your thoughts?
Oliver
SitKneelBend
St. Louis
3.6 Pentastar
Hi,
Oliver
If I caught you are purchase I would have told you to get a Rambox bed. That being said if a bed swap is an option you'd entertain you could still go the Rambox route...
P
PedalToTheMetal
Novi, MI USA
5.7L HEMI
Thanks for your response!
I would have liked a Rambox, but don't recall ever seeing a used 2018 Bigh Horn with one.
I also don't want to put too much money an effort into this and am therefore looking for a solution that I can either buy or build on a Saturday.
SitKneelBend
St. Louis
3.6 Pentastar
I understand, just throwing out the bed swap idea because sometimes there are people that will straight swap for free, do the labor, and if you are lucky also have the right color!
KPMH
Chicago Area
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
May i suggest a simple solution
First don't use wood on the fold flat floor, on the chance that you are involved in a severe accident, wood hurts if you are struck by it
A better solution is to use plastic bins like you can find at places like Home Depot.
Then take the type of velcro that is sticky on one side & has the Hook & loop style on the other side.
Attach the sticky side to the bottom of the plastic bins & the carpet that covers the Fold Flat floor grabs onto the hook & loop side.
The hook & loop part grips nicely to the carpet, but it will detach with a good tug.
I use this solution to hold my First Aid & Travel kits in place, they never move, until i jerk on them
I see that the organizer mentioned above, has the velcro i mentioned glued to what i think is the panels
https://www.amazon.com/TrunkCratePr...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
P
PedalToTheMetal
Novi, MI USA
5.7L HEMI
Thank you guys, I love the velcro + plastic bin idea!
The organizer, that I already have, didn't come with velcro, so I will get one like above. For my file storage box and maybe an additional plastic bin, I will simply get some velcro with adhesive backing from Amazon!
PoMansRam
East Aurora NY
I like the plastic bin idea as GTyankee suggested. I've done that for rear storage on other vehicles i've owned.
Is your 2018 quad cab a fold-flat with the split rear seat or does it have the carpeted recesses under a once piece rear seat bottom?
You can remove the rear seat relatively easily. Four 19mm bolts that are in TIGHT. If you want to keep the seat and are willing to remove the bolts temporarily, you can do a simple mod that allows the rear seat back to fold forward, giving you some more storage space behind the seat back.
P
PedalToTheMetal
Novi, MI USA
5.7L HEMI
I am not exactly sure what you mean: My rear seats are split, the platform also folds out in two pieces.
I have seen the seat back fold down mod but would probably rather just remove the seat(s) altogether.
VA-RAM
STL, MO - Norfolk, VA
2017 Laramie / 2020 Laramie
My wife had this exact storage container in the rear of her Durango..held everyhting she needed for being on the road, extra water, blankets, emergency equipment, etc. that thing never moved and with a good tug, it came loose.
She actually had it in her 1999 Bravada and moved in into the Durango. Now she has a 2020 Laramie and all the storage boxes and compartments work for what she needs now...plus a Truxedo bed luggage kit.
MikeSumthin
US
As far as the brochures and folders are concerned, get the organizers that attach to the rear of the two front seats...
They even have some slick tactical ones on Amazon.
Sent from my SM-G988U1 using Tapatalk
Joe_Clark
Kingsbury, TX
I have a milk crate with a bungie cord on the smaller jump seat portion of the flat floor panel.
I can shoot some pics in the morning if you want.
sent from a device using an app
