Clock problems!!
ramguy11
The only thing I have added to the truck "electrically" speaking is the HID's and their harnesses.
My clock either gets stuck on the time I set or it will restart to 12:00 after the truck is turned off a while.....
Has anyone had any problems with their clock??
Savfil
Moose Jaw, Saskatchewan
2012 - SLT
That sounds like there may be a short somewhere in the system that is causing this... I know that if you disconnect the battery ever, the clock resets to 12:00. Perhaps you have something crossed in the headlight harness? When did it start happening?
ramguy11
ramguy11
Now it is just behind. I set it to a minute ahead of my phone to 11:58. Killed the truck went into the store now it read 12:02 while my phone reads 12:03.... What the hell
Savfil
2012 - SLT
It sounds more like a slow drain somewhere then, does anything else reset itself? For example, set a couple FM stations to a preset, and if they reset as with the clock, then it's an electrical drain somewhere... if not, I'm wondering if it may be a faulty head unit, although rare it can happen.
ramguy11
ramguy11
I just checked that. Two good minds think alike lol
All my presets are the same and good to go....
Now the clock is functioning fine it seems but the truck is running....
Savfil
2012 - SLT
Hm, with the truck running it will draw all electrical power from the alternator, so the only way to really test is with it off. Quick suggestion, check the battery terminals are well connected, as well as your HID controller/ ballasts and wires for shorts/ good connection.
