Cluster Lights
Casey Westergard
Iowa
I am new here so might have done this wrong. but on my 2014 2500 Larimie with the Cummins. My instrument cluster with lights in the off position the screen between the gauges will flash on and off. But when the light or on they stay on. Thanks
Fast69Mopar
Does the EVIC screen flash on and off constantly or does the EVIC come on and turn off once after you turn the ignition key to the off position?
C
Casey Westergard
Iowa
It is constantly when the key is on light off. But when lights are on it works good no flashing. But if you bring the interior dimmer switch al the way to the brightest it starts flashing again. Thanks
MikeSumthin
US
Seen this before... not a real common issue, but the mechanic said it was a faulty cluster.
Sent from my SM-G988U1 using Tapatalk
mikep345
