Caine espinoza
this might be a dumb question but i genuinely dont know so hear it is lol
im thinking about sending my 5.7 eagle heads to mmx for porting and im curious if im going to need new larger valves because of the porting or will the valves that are in it work. i just had a complete valve job and pac racing springs installed about 60 miles ago with the texas speed stage 2 cam job. i belive i have a bad rod bearing or a main bearing because of a new low end knock so ive decided to go balls deep and buy a 5.7 based 392 stroker for it and i know ported heads along with a good intake would be best for the build.
my next question is do you guys think i should look into the edelbrock hemi heads or just port the eagle heads i have? its about $1500 to have them ported by mmx and about $2500 for a set of edelbrock heads from mmx.
theres nothing cheap about building a hemi so id like so get the most bang for my buck if im gonna spend the money.
thanks
thanks
