code reader for Dodge Ram air suspension
06 Dodge
Forest Grove, Oregon
6.7L CTD
Well, technically……..the rear/four-corner air suspension is supposed to be a sealed system that uses nitrogen but, they made the system to where it can purge some of that nitrogen and supposedly draw in small amounts of outside air as well.
Even in a closed system you will collect condensation from temp changes...
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Egh, I beg to differ. I believe that’s why it’s a closed system- well, supposed to be, anyways, with nitrogen. It’s purely a design flaw in my opinion making it to where it can purge the nitrogen out for whatever reason and pull in air from the outside. That’s where the condensation comes from because if it truly was a closed system, there’d be no moisture to get in there to begin with.
Articlonestar
Maine
The alphaobd software does not come with the OBD2 scanner. It would be an app in your phone store that costs about $50. Well worth it if you plan on doing anything to your vehicle
