QwikKota
- Apr 2, 2015
- 1,528
- 1,112
- 2015
- 5.7L
My truck had thrown an initial P0463 code (fuel level sensor high) after installing a dash cam hard wire kit with fuse taps. The initial fuses I removed for power were the underhood light F60 and Ignition module F51 for constant power and accessory power. I moved the accessory power to a sunroof fuse F66 and cleared the codes. I drove the truck for a few days without issue. On Wednesday I went to start the truck and it died after about 30 seconds. I figured it was the battery since I had the doors open and ignition on for a good while the weekend before.
I put in a new battery Thursday morning and similarly it only ran for about 30 seconds. The code that popped up was U0100, PCM comm error. I disconnected the battery for a while but same issue. I checked continuity on all fuses and don't see any breaks. I swapped the headlight and the ignition relay and no change. Any thoughts on how the fuse taps and comm error could be related?
