powderbrad
Heys Guys,
Truck is starting like ****, and I thought it was due to being -28C over the weekend when I was attempting to start. It starts, but hesitates. I figured my block heater wasn't doing its job since it was plugged in for well over 12 hours. Tested resistance....26.7 OHMS. So it should be OK...I think.
Checked codes, and in ADDITION to the 3 02 sensor codes Ive been getting I now have a P0300 (ENGINE MISFIRE DETECTED)
I checked my air cleaner, the sensor, and to make sure it was tight. COP connectors tight and injector clips tight. I tightened up some exhaust clamps (for the millionth ******** time. Maybe itll help the 02 codes ive been having)
Wouldn't think plugs, as Ive only 19000 kms on it (12000 miles or so)
What else to check? I wouldn't think the intake manifold would be leaking but I didn't spray / snoop it to find out. I never did tighten the bolts to see, either.
I don't like when the engine is running LEAN (based on high voltage 02 codes im reading) and it freaks me out.
I haven't ruled out that the HEMIFEVER tune is messing with the system. I have yet to load a stock tune back in to see.
Any other ideas guys??
