coil spring swap
derail
michigan
I can't get my phone to do a search for me so I am going to ask a question that I'm sure has already been talked about.....has anyone swaped out their half ton coil springs with 3/4 ton? I have a 2011 1500.....
14hemiexpress
6.4l
Not that I know of but there is a company that sells upgraded coils for the 1/2 ton Dodge Products
Have you tried the airlift 1000 bags?
derail
derail
michigan
Didnt really want to have to mess with air....thought will different coils it would be a one time deal....
loveracing1988
Clarkston, MI
Your not going to get 3/4 ton coils on a half ton, they are way too big. Just get the upgraded coils and be done with it.
audio1der
Airdrie, Alberta
^Truth. TTC springs has +50% and +25% capacity springs. No fuss. no muss. I swapped in RCSB 2WD springs to my CCSB 4WD; they're the same.
mtofell
Stick with your stock springs and get air bags. Why would you want the harsh, bumpy ride of a 3/4 ton in a 1/2 ton truck all the time? My 1/2 tons drove like a Cadillac compared to my 2500. Ride quality is the #1 complaint of people with HD trucks and the rear springs are the #1 thing that contributes to it.
Statcher1
Kentucky
Yeah airbags will be your best and most comfortable option.
NYCruiser
Yonkers, NY
I'd get after market coils made for 1500. I think I've seen some that are variable rate so you won't have a harsh ride when empty
StevoTee
TTC springs is supposedly coming out with a +50% that retains stock ride height. The +50% they have now actually raise the truck because it's a stiffer coil.
They also sell variable rate coils.
I had the airlift bags and will be switching to TTC springs in the New Year. I found that the airlift kit leaked air (only installed a couple months). Would rather trust a metal coil, instead of an air filled plastic bag.
derail
derail
michigan
OK thanks everyone....I'm gonna chck into the TTC springs....I don't want the problems StevoTee ran into with air...
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
just got an email back from Tuf Truck Springs. He said the 50% increase springs could raise the rear end up to 4"'s when empty... too much for me
SuperBeaner
Austin, Texas
Im running the Total Load Control bags on my 1500 and i couldnt be happier.
smurfs_of_war
Swift Current, Saskatchewan
If you put in a lift strut or leveling kit up front as well, it returns to near stock rake. Just an idea for you. That's what I ended up having to do.
Sent from my SGH-I337M using Tapatalk
zogg
Southern Illinois
2018 Ram Express Quad Cab
I traded my 3/4 ton truck for a half ton because I hated the ride. Put air bags on my half ton and it is wonderful....no leaks in almost a year and I get the nicer ride daily.....
