Jeff Krawczyk
I installed a 6inch lift on my ram right after buying it and now want to upgrade to coilovers looking for a site to find them, any suggestions.
Thanks, that's what I think I'm going to do is get the fox co from their ram 6 lift, just have to figure out the rear...will look into the 2.5 from the 2500 kit...Fabtech have a performance package with Dirtlogic 2.5 COs for the front and Dirtlogic 2.25 shocks for the rear they use in their 6” lift. You can call and ask only for the COs and shocks.
Fox also have couple of options for 2.5 CO’s (without or with DSC) that will fit 6” lift. They make those for BDS 6” lift but they don’t have a matching 2.5 version for the back of the RAM 1500. So you can go with The Fox-BDS 2.0 rear shocks for their 6” lift or do Fox 2.5 for the 2500’s that will match the length you need for 6” lift in your truck or go ask Fox for 2.5 rear shocks valved for a 1500 on the same length they have for their 6” BDS 2.0 rear shock.
Other options is go custom length with King,Icon or Radflo, don’t believe SAW make COs or shocks for the 1500’s but it wouldn’t hurt to ask if you wanted something from that brand.
Good luck.
Here to make the search easier for you.Thanks, that's what I think I'm going to do is get the fox co from their ram 6 lift, just have to figure out the rear...will look into the 2.5 from the 2500 kit...
Great this will save me a ton of time as I tried to look a little bit before work and had a hard time, I'm not great with searching thingsHere to make the search easier for you.
Front:
Fox 2.5 Coilovers with RES (4-6"),Part# 883-02-073, 26.57"extended, 20.38" Compressed
Fox 2.5 Coilovers with RES + DSC (4-6"),Part# 883-06-073, 26.57" Extended, 20.38" compressed
Rear:
Fox 2.5 with RES, part# 883-24-024, 29.39" extended, 18.25" compressed
Fox 2.5 with RES + DSC, Part# 883-26-024, 29.39" extended, 18.25" compressed
This are basically same shocks found in the old 1500/2500, fit like like a glove in the 4th gen 1500's.
Np, check with the 6" lift folks around here if this lenght will suite 6" lift better, i guess it'll depends on what you have now as well.Great this will save me a ton of time as I tried to look a little bit before work and had a hard time, I'm not great with searching things
Do you have or carry these fox 2.5 that are mentioned here, or do you carry or have access to kings that would fit a 6 inch lifted ram 2014...looking for front and backLet us know if we can help. We offer Fox, Icon, King, etc.....
Accutune offroad, Filthy Motorsport etc. This dudes are tuners so they know a thing or two about offroad suspensions.Do you happen to know a good site for the kings that you can have made to custom length...or for a 6inch lift
