Column Shifter issue
Donnyboi
Vancouver Island
I have recently begun to notice a very loud clicking sound when pulling the column shifter out of the locked park position (See attached video)
It started with an issue when I went to put the truck in park, It read Reverse on the display, would physically go into park while only reading reverse. And in order to remove the key or turn on truck I had to pull very hard on the shifter column to get it into neutral to remove key/start truck etc.
That problem seemed to correct itself, however I then noticed the sound the shifter made while moving it while still in park. It doesn't make this sound when in any other gear. And it is very loud.
I took it to the dealership and they said that the sound is normal. I was hoping to get some other oppinions. Have a look and listen and tell me what you figure.
I have a weird feeling that I am being lied to by the dealership, perhaps to avoid installing the warrantied part. As I had the exact same part reinstalled less than 2 years ago due to complete failure.
The truck is a 2014 ram 1500 5.7. Any input would be much appreciated.
TheEnder
4.7L V8
I have a weird feeling that I am being lied to by the dealership, perhaps to avoid installing the warrantied pard. As I had the exact same part reinstalled less than 2 years ago due to complete failure.
That clicking sound is your BTSI (Brake Transmission Shift Interlock) module.
It’s normal for it to make that sound in park, as if it didn’t, the vehicle would be able to go into any other gear without needing a key and roll off and into traffic.
My truck makes the same noise, and i can post up a video if you want me to of it making the noise.
D
Donnyboi
Vancouver Island
If it's no problem I would like for you to do that.
Maybe it's just me paying more attention to it. Just seems very loud to me now.
Thanks for the response.
Hemi395
Cape Cod MA
My 2013 has the console shifter but when you move it to the right like you're putting it in reverse, it makes that sound as well. Dont think its quite that loud but that might be the difference between the column vs console shifters....
TheEnder
4.7L V8
I’ll do it and post it up in a few then.
TheEnder
4.7L V8
This is what it sounds like on my 2013 Bighorn, same trans but i have the 4.7.
TheEnder
4.7L V8
Oh wow that is quite loud. I can't believe I went this long without noticing.
Thanks for the vid that puts my mind to rest alot.
You’re not the only one, i’ve seen a few people who don’t notice it until one day they do. I was one of them, lol. You’re welcome.
This video is lousy because it as filmed with a damn smart phone & the guy just rambles on
beginning at about the 6 minute mark, the guy gets more into the meat of his issue.
Notice the pin on the part he holds, there is a pin that is has been known to come loose, that may be your issue with the noise
If you want to look at yours, you may want to watch a video made by MotorCity Mechanic, i believe he shows how to replace the Multifunction Switch on a Ram, during the process, he takes the steering column cover off, then you can see & inspect the parts
