- Dec 1, 2013
- 12,803
- 12,500
- Location
- Bristol , Tn.
- 2014 4X4 QC Express 6 speed auto 355 differentials
- 5.7 Hemi
My truck = 2014 RAM EXPRESS 4X4 5.7L 6 SPEED XSMN 3.55 DIFFERENTIALS.
I will be adding ( EDITING ) to this O.P. ( Original Post ) as I complete this install .
Well I've done some mods , as far as the COMPASS MODULE, install it's important to know : my truck was an original RA1 NO frills non touchscreen radio. Also I did not and do not have an overhead console .
I have upgraded to the RA4 8.4NA Radio , steering wheel audio controls , VR /Phone button and a 911/assist mirror with microphones.
Through much help from folks on the forum here , I've been able to find out the pinout of the compass module and location of the original truck side connector .
These are pics of my truck as originally left the factory .
This is the connector that the compass module /homelink / overhead console type wiring would normally run through . It's located on the drivers side below the headlight dial as depicted in the photos below .
As you can see the lower side is populated @ sockets #1 , #2 & #8 on the top row .
Bottom row it's populated @ #s 10,11, and 16 .
On the outgoing side it's only populated on socket #s 16 & #11.
This means only two wires are completing a circuit for something ? Not positive on what that is .
☆☆☆EDIT ☆☆☆
The two wires I met ione above are for my Dome light , #16 black is Ground , # 11 yellow/Violet completes the + circuit through the BCM .
This write up is about the compass module ONLY install so ...
Through the research I've eluded to above the compass module wiring only consist of 3ea wires :
@ the module #1 RED 20ga. wire is a fused B+
#2 BLACK wire 20ga. is Ground
#3 Orange & Violet wire 22ga. Is LIN BUS CBC2
GREAT looks like my Express is wired for the compass module !
Because I've researched and determined the #1 from the compass module goes to the # 1 of this connector , and the #2 from the module goes to #8 (ground ) or #16 (ground) of the connector and finally #3 from the compass module goes to # 2 of this connector.
Now I just need to obtain the proper pins or sockets to install on my The Harness Connection Home harness ( special order from CuylerTech " a member here" ) to install via ( plug n play ) as factory . To install my compass module .
I should mention I've already had Sales code CV2 Flashed in by my Dealer .
This is a picture of my compass module and the www.harness-connection.us special ordered harness , that did not come with the connector end socket / pin fixtures nevertheless. ...
This is a picture of my wiring notes for anyone interested in completing this themselves .
What I'm doing this for : I want my directional heading to display in my instrument cluster and on my upgraded RA4 NA radio .
I'm not positive this will work but I am extremely optimistic in this case ...
Wish me luck ! Once I get the proper sockets / pins I'll be posting the results !
☆☆☆☆☆☆☆EDIT ☆☆☆☆☆☆☆☆
I've disconnected the green connector behind the drivers vent and verified I definitely need sockets on my harness .
This is the bottom (truck side ) of this connector .
And this is the top side ( that I'd be plugging into)
Anyone happen to know the p/n of the sockets I require ?
☆☆☆☆☆☆END EDIT☆☆☆☆☆☆☆
I could just solder splice into the proper wires ( and I may end up doing that ) but I want to install it like a factory install ...**** I know .
Things I'm not sure of :
1) is the compass module Location and Direction spacific ?
Can I just mount it anywhere ? OR. Must I mount it in the O/H console location and pointing the proper direction for accuracy ?
☆☆☆EDIT ☆☆☆
