compressing coil spring
S
scotts2012ram
Guest
Could I compress the springs on the back with the kit you can get at autozone. I really don't want to cut the springs because if I want to go back to stock height.
quietpeen
2021 TRX
Hellcat
what kit are you talking about.
S
scotts2012ram
Guest
Its the one with the brackets and bolts that go in the spring
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
We did a lift kit on a jeep with those spring compressors. They work well enough. And as long as your drop the axle and raise the body enough you should be able to just slide the coil out. Or only have to compress it a little.
sphincter
The spring compressors are not meant to be used permanently. They're just for removing the spring from the rest of the assembly. If you rent a set from Autozone you'll get two compressors, which enough to compress one spring. Also, the springs won't even fit back into the assembly with the compressors attached. I used them to install my Bilstein shocks about a month ago.
schroederMP
Indiana
Cummins
I would not recommend that. Or anything that compresses the springs with a clamp for lowering the truck..
Either cut em or get a kit man...JMO
1500ram12
5.9L Cummins
thats what i was thinking at first but what he is talking about is a actual spring compressing lower/lift kit. I never heard of it before. I still wouldn't go that route though.
Stangshcky12
Oshkosh, WI
5.9 Cummins
They're similar to the spring compressors your talking about but are made to actually stay in
I've bent normal spring compressors before I wouldn't want to drive around with them knowing how much tension is in these truck springs
Maybe on a civic lol
HemiBabe
DFW
That is the old school method of lowering a vehicle, over time it will completely ruin the spring and suspension... I would think cutting them would be better for it and it's free lol
sphincter
My mistake lol. I didn't know they even made such a thing, so I assumed you meant the spring compressors they have available for rent.
BlackedOutHemi
DFW, Texas
2012 & 2012
That's what I thought he meant too.
shaunnz
