Compressor kits
stateofdade
Trenton, GA
Cummins 6.7
I've been doing a bit of digging to find information on different compressor kits. I have airbags, but I'm price shopping the compressor kits. The problem I'm running into is that the vast majority of the info is about Air Lift brand stuff (expensive). I can't even find adequate info on the Firestone kits and the Viair is non-existent on relevant information. Are there other brands out there too? Does anyone have any information about a standard duty kit that I may use once a month? I don't want to spend 300+ right now.
If your using the airbags only once a month or less, get yourself a portable battery powered tire inflater. I use this one with my TLC airbags, they are larger than most airbags on the market and it has no problems inflating them to whatever pressure I need. I have both airbags piped together. Fineed Portable Air Compressor https://www.amazon.com/dp/B019FIERRO/
You can get the first gen AirLift WirelessOne compressor kit for about $300 on Amazon (at the time of posting) Air Lift 25870 WirelessOne https://www.amazon.com/dp/B005JUX1S4/
My buddy uses this on his 2500 with rear airbags and hauls a large fiver.
stateofdade
stateofdade
Trenton, GA
Cummins 6.7
So that first one would have no issues inflating Air Lift 1000 HD's?
OC455
Central NY
I bought my GenI Air Lift WirelessOne off of ebay for $270ish something.
Just looked, surprised the prices have gone up on them. Even the GenI's gone up in price.
stateofdade
stateofdade
Trenton, GA
Cummins 6.7
Yeah, that's why I'd rather find a less expensive solution. I got the 1000HD bags already.
Sent from my SM-G935U using Tapatalk
Mountaineer83
Charleston, WV
I use this one from Harbor Freight:
https://www.harborfreight.com/12volt-150-psi-compact-air-compressor-63184.html
It was like $50 with the 20% off coupon and it works good for pumping up my Firestone Ride Rite bags. I hook it to the battery on my 5th wheel and pump the bags up that way. I like you didn't want to spend the money for the on board kit for the few times a year I use it. Plus side, this little thing will pump up my truck tires/trailer tires if needed.
Damion
2019 Sport
I just picked up a 12v compressor for my 1000hd bags, it has no issues filling the bags to capacity and only takes a minute. You also have the added benefit of having a small air compressor for other tasks as well. And for $50 or so it’s a cheap investment
