Connecting rod
New2dodge
4.7L
So I installed my connecting rods this weekend and whenever i torqued them down i couldn't spin the crank. Has anyone ever ran into to this before? Spins fine until i torque them and then can't move it at all. engine is a 4.7l
HarryS
Air Force
Clovis NM
Did you plastigage the rod bearings? Did you center the crank?
N
New2dodge
4.7L
I didn't use plastigage. I will go get that today. I'll check the rod and make sure they are all facing the right way. I'm pretty sure they are. Thank y'all for the replies. I was reading somewhere that the bearing could be backwards but there isn't a tab on them like the crankshaft bearings. How would you know if they were backwards?
N
New2dodge
4.7L
Unfortunately I don’t have much of a choice. I don’t have the money to have someone do it for me. So I’m trying to learn. I’ve done engine work before but never anything to do with the pistons and crankshaft.
HarryS
Air Force
Clovis NM
A simple mistake can cost you an engine. Think about that when you decide what you can and can't afford.
stevenmicheal
