Coolant dipstick dry
sgtryanusmc
I was looking for whatever could be making the mildew smell inside the truck. Found nothing so looked under the hood.
Poking around under the hood and pull the coolant reservoir dipstick and its DRY. No leaks. Very odd. Any thoughts?
gofishn
Iowa
hemi 5.7L, 345 cu in
check pad under your pssger side carpet for wetness.
ps
btw, ever replace your third brake light gasket?
U&A
2016 3500 SRW
6.4 HEMI
The 1/2 ton had a coolant dip stick....?
Thats odd.
Sent while firmly grasping my redline lubed RAM [emoji231]
blue ghost
Pennsylvania
2013 Ram 1500 sport
refil and check for leak coming out under truck, they may have a external leak port to keep it from going in truck, but smell gives it away.
Administrator
Fill the reservoir and check the radiator if it's full. If you buy the concentrated OAT coolant, use either distilled or deionized water to dilute. When was the last time you checked the level? If the coolant was leaking into the cab, you would most like have a "sweet" smell in the cab.
OCDTech
Louisiana
Thats odd.
Yep, mine does, one of the first things i ever noticed when looking under the hood, Weirdest thing i've seen on a truck in a while, its LONNNG too, like 18 inches or something.
No jokes please...:angels2:
U&A
2016 3500 SRW
6.4 HEMI
Seriously.
This can not go without a joke!!!
TWSS!!
OCDTech
Louisiana
Seriously i get nervous when people talk of coolant going missing, that not good.
I get the same nervousness when i see moisture just above my defrost vents in my other two cars sometimes,
To the OP, put some more coolant in there and keep watching.
And if you havent just do the 3rd brake light fix, so easy.
jlongjohn
PA
Technically the dipstick you are referring to is in the overflow tank. The smell may or may not be related. Do you ever smell coolant after driving? I just got done replacing a radiator on mine, the resistor was seeping at the bottom passenger corner where it crimps together. I could smell the sweet collar smell after drives that were long enough to get the engine to full operating temps. I noticed the seeping underneath during an oil change near where the bottom radiator cover is, and near the tow hook mounting area.
I would check your coolant in the radiator. Do when cool. The water pump is another culprit for minor leaks, as well as the many hose connections.
As others have mentioned you could have just a water leak from rain, etc, from window seals or third brake light. That gives more of a musty smell compared to the sweet odor of coolant.
2014 Ram 1500 5.7l CrewCab
Sent via Tapatalk
RoadRamblerNJ
Knoxville, TN
392 Hemi
Sounds like your other 2 cars might have bad heater core. Foggy vents, damp & slippery passenger floor and that sweet smell. Been there. Don't want to ever be there again.
OCDTech
Louisiana
Yea thats what im afraid of. They just be my summer cars then lol
Judy
Midwest
Seriously.
TWSS!!
omg...... long dipsticks and lube.... what is a girl to do?
