Engine coolant filters do not mount in-line with the radiator water flow. They connect to a heater hose and are designed to bypass and continually filter small amounts of the engine’s coolant. They are very effective, do not interfere with coolant flow, and cannot "clog and devastate an engine".I would never filter coolant, that is a filter that could clog and devastate an engine pretty quickly. If you use distilled water and good coolant, there is no need anyway. Water needs to flow fast to do it's job, it is never a good idea to slow it down in the name of filtration that isn't needed anyway.
