coolant refractometer recommendation???
srv1
blasdell n.y
345 c.i. HEMI MAGNUM
just did a coolant flush.tested with a hydrometer but i dont trust its accuracy.i am looking to purchase a refractometer.i was looking on amazon ,there are several for around 20 bucks but i have never used one and i dont want to end up with a pc. of **** that is less accurate than my hydrometer.i would prefer a farenheight reading and i am running zerex g05.any help would be greatly appreciated.
S
srv1
blasdell n.y
anyone own a refractometer?do you like it or not?is it accurate?
John Jensen
San Diego County
Ecodiesel
S
srv1
blasdell n.y
thank you for the info guys,appreciate it.
S
srv1
blasdell n.y
chri5k
USA
Diesel
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
LOL. I Like the ad for that one. It shows a sealed AGM battery so I am not sure how you would use it test the battery electrolyte.
I didn't notice that back then when I bought it so maybe they changed the ad. Atleast it's an acid battery and they didn't show a lithium ion.
I used it to see the condition of my golf car batteries' cells. I see it's a couple more bucks now too.
S
srv1
blasdell n.y
With DEF issues that can arise if the fluid concentrations are off, I bought this one for $16. It's a 4 in one and from my tests and experience it is accurate following the instructions recommendations.
https://www.amazon.com/dp/B07ZV6YBTJ/ref=cm_sw_r_cp_awdb_imm_t1_V2aTFbGSH4M67?_encoding=UTF8&psc=1
thats the one i just bought.i pd. about 2.00 more but whatever.pretty f----- up how prices fluctuate so much on amazon.i just found out about the "honey"app that can help you keep an eye on that ****.very glad i bought a refractometer,my hydrometer was off about 20 degrees.i now have my anti freeze mix at -40 f which is about 52%..also checked my rain x windsheild fluid just for the hell of it since it measures that too.the label says -20 f i got +10 f.so either this refractometer is not accurate or more likely rain x is full of ****.
John Jensen
San Diego County
Ecodiesel
I believe the refractometer instructions tells you how to check the accuracy and calibrate it using distilled water
S
srv1
blasdell n.y
i calabrate before every use but i mean 20.00 from amazon,can i really trust this thing?
JEFF MANN
Ajo, Arizona
3.0 ECODIESEL
I think it will be fine, I ordered one that just does DEF, it was about 25 bucks, I would be more leery of a 3 in 1 or a 4 in 1 without knowing more about them. Irregardless they all work on PH measurement so it shouldn't be an issue, I'm pleased with mine, & yes they can be calibrated with distilled water and are very easy to read.
