judgeclan
Towed a trailer full of hay home, engine felt a little warm, engine coolant normal on dash, went to the towing and trailering section on my digital screen and the coolant temp showed 419F with engine off in the ACC position. All other parameters in normal range. Later after breathing a little bit, if I switch to "run" but don't start the truck or if I start the truck the gage returns to normal temperature. Dealer states because it works when engine runs it's just wonky and an anomaly when in the off or ACC position. Something to do with the PCM but not worth swapping parts. The coolant gage readout on the off road section does not do the same but I think its the same sensor, just a different screen. Appreciate any thoughts.
