Coolant Temp
Troutman
3.6 pentastar
My 1500 with 3.6 pentastar runs between 224 and 230. Is this normal
Kotta390
I want to say I saw a TSB somewhere about a water pump issue that the 3.6L has or it could have been a thermostat issue? 230 is pretty toasty but not enough to damage the engine. I would take it in under warranty.
BlownGP
Houston/Baton Rouge
230 is pretty high, but I think that's normal for that engine.
Somebody had the same question a while ago with the 3.6L.
Was this just sitting at idle?
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
My last vehicle was a Wrangler with the 3.6. It ran pretty hot also at 225 degree but that seem to be the norm. Anything above 245 degrees seems to be where things get dicey.
LB3711
Trumbull, CT
3.6L V6
wow crazy high. my 2011 doesn't get above 210 deg F
darthdzl
Phoenix, AZ
2017 Tradesman RCSB
V6
In hot/warm weather, while towing or in stop and go traffic, it seems like that would be normal.
Mine ran 220+ frequently here in the Phoenix summer, but not all the time. It mostly hovered around 215. That was a RCSB with no passengers, cargo, or towing, and I try to stick to freeways.
CMSBusDriver
