Coolant Temperature Fluctuation, why does this happen?
Davidloveshishemi
Tn
2019 Ram 1500 Classic
5.7 L Hemi
It seems like all Ram 1500's coolant temperatures fluctuate, and I know the active shutters warm the truck up faster but why the wide temperature range? I know its part of it and thats just the way the trucks are. But I have never got a reason why.
Again, I know it isnt a big deal but any explanation would be greatly appreciated. Seems like mine and everyone elses has done it since day one, thought I would ask.
Thanks In Advance!
Burla
2010 Hemi Reg Cab 4x4
You have to mention the temps man.
Most likely t-stat stuck. OEM should run around 203-204 all the time when warm. If the truck working hard could be higher, but wont fluctuate unless something else wrong.
Davidloveshishemi
Davidloveshishemi
Tn
5.7 L Hemi
From 194-210, with an average of 203. Took it to the dealership, no issues. Thought the coolant was low and they ran a pressure test, nothing. They filled it back up and its fine, but its always had the temperature fluctuations, along with everyone else I have asked.
NOV87
PNW
That's how mine fluctuates too
BadHemi2014
Greater Cincinnati area
Sounds like mine, seems pretty normal to me. Mine doesn't have the active shutters. When 1st driving will get to 210 or so, then drops to like 195, then hovers around 203 but still fluctuates between 195ish and 205ish. New heater core, hoses, thermostat, rad cap.
I forget the location of the coolant temp sensor on these trucks? That might have something to do with it. I assume cooled coolant from radiator flows past sensor, thermostat shuts, coolant warms up, thermostat opens etc. Normal cycle. If it fluctuates more than that, runs over 203 all the time or doesn't warm up, then you have a problem.
turkeybird56
Central Texas
Yep, in that range and sometimes up and down, depending if I am towing and also what time of year here. In Aug-Sept we could get weeks of over 100 F temps.
Burla
Mine never fluctuates 2010 ram, almost religiously hovers 203-204, never drops below 203/2 when warm, and I never seen it above 206f. Having said that I wouldnt be overly worried if it did it with only 10f swings, so I had no idea some rams did this. It probably isnt t stat then, that is what you get when you post the temps. The temp is dropping 10f lower then t stat opens, and is well over what you would expect with an open t stat at that temp, so something else is at play would be my guess. Maybe just a gauge reading, maybe faulty maybe not, but nothing really to worry about. t stat is cheap enough next time you flush coolant maybe replace it, see it anything happens, worth knowing for sure anyhow.
caulk04
How long are you driving?
I tend to see the same range mentioned above. Up to maybe 210, down to ~195 and bounce around there to 201-203 until it finally equalizes at the 201-203.
It doesn't fully equalize until 30 minutes or so, rural driving.
Davidloveshishemi
Davidloveshishemi
Tn
5.7 L Hemi
Thats basically what mine does, once I have driven for 30 minutes or so it evens out to between 201-203. It just takes that long for everything to warm up. Sounds normal according to what everyone else is seeing. Thank you again!
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
looking straight at your 5.7l water pump
at the top left, you should see a plug screwed into the pump
That plug is for releasing AIR from the system, so Air Bleeding Plug
Now look at the right side of the water pump, if you notice the fitting & the wires, that can also be used for bleeding the cooling system, but it is actually the Temperature Sensor
You don't have to have the engine running when you use either the water pump plug or the Temperature sensor to get the air out of the system.
Motorcity Mechanic on air bleeding the hemi coolant system
I wanted just to state an observation on my 2017 Ram 1500, 5.7 L, I also have a temperature fluxuation on long hauls, especially at higher speeds and long hill climbing.
The coolant temperature slowly rises to 220 degrees F than quickly drops to about 192 degrees F. Then repeats. Lower speeds it stays steady.
At first I thought maybe the cooling system had a problem, maybe the thermostat was sticking.
Then I started to read more about the active grill shutters (AGS) that open when the engine coolant temp gets a certain predetermined temperature. I suspect the AGS will open briefly at higher speeds to reduce coolant temperatures and then close again.
I concluded, this was a normal operating condition of the engine and was not a problem.
theclassic
Grass valley
Assuming your truck has active grills shutters. Check this out.
Mine did the same thing until I removed some of the shutters.
The temperature stays pretty constant now.
