Core 4x4 and Hellwig
Nate Alger
Spokane Valley, Washington
So I have been reading on the forums a little about my issue.
I have a '14 Ram 1500 Express and had a 4" lift put on it. I noticed when camping this weekend that whenever i hit pot holes in succession/washboard roads that my ass end wants to come out from under me.
I just ordered Core 4x4 Adjustable rear control arms, the full set, Core 4x4 Adjustable Rear Panhard bar and a hellwig sway bar.
From what I have been reading, that should improve my issue, but before it ships out I would just like some confirmation as it was a little over 1200.00 in parts.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
You "SHOULD" be fine, but washboard roads are going to have that kind of impact on your stability regardless of what set up you have in my opinion, our rear ends are not that heavy so those washboard roads are going to send the rear end where it can ...
But you "ARE" going to see a big difference ... I only got the lower control arms from CORE 4X4 and it helped my truck's stability by a lot !
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
I went with the whole set as well, including rear end links and the hellwig. I live in an isolated community nothing but pot hole infested roads. Huge difference in the truck with those upgrades. I’m running a 9” lift and 37s and the truck is running awesome. I’d recommend the core 4x4 setup to anyone, stock,lifted, off-roading, or daily driver!
Nate Alger
Nate Alger
Hell yeah. Thank you guys for the confirmation. I did get three colored control arms in the bright green. How gates do toy think it would be to have the sway bar color matched?
2018 2wd
Let's see yer rig my friend!
Sent from my SM-T387V using Tapatalk
DILLIGAF
Canadian Forces
Canada
The Hellwig stuff rusts pretty quick up here, so definitely powder coat them The Hellwig sway bar end link rusted in 1 winter... lol...
Lyle Longboat
C74F9258-F082-414A-B081-9469C5C88812.jpeg 2D910521-56AD-4871-AE5A-8AD84506F27D.jpeg 79647E2C-B022-4B93-AFFD-7AC4863A8036.jpeg
Here is some I have. I noticed I don’t have any of after my Hellwig was installed. I’ll have to grab one of the whole back end once my truck arrives back into isolation next Thursday.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
View attachment 214148 I did find this one of a pic I took after installing train horns. It shows the Wig.
More info on that train horn setup please!?!?
Side note another useless pic to confirm Core 4x4 5-link set will fix your ass end kicking out.
Now get the Core 4x4 swaybar rear end links
I waited 2 years asking repeatedly for Core to make front swaybar endings. Finally gave up and dialed up SuspensionMaxx. I never thought I'd recommend $250-$300 worth of sway bar links but I'm serious when I say these products work and you're getting your money's worth.
2018 2wd
That looks sexy !
Lyle Longboat
476F9BB9-1C52-4A36-A267-7BC4B8C64275.jpeg DF7A7A85-43CD-4219-89C6-2FA3CF5DA9E4.jpeg 9119B483-1B39-4BDD-AB84-6AF80D2DC382.jpeg 0590ABC6-DB97-4815-942F-01999BAC8AC6.jpeg The train horns are the Wolo Cannon Ball Express Pro. Very easy install. I done away with the spare (37s) and fabbed up 2 brackets to hold the train horns to the spare tire mount. The compressor (Tornado) is sitting on top of the spare tire cross member and drilled/bolted down. The horns are bolted to the cross member going from axel frame to spare tire frame. They are pretty damn loud. I have the compressor running to a switch in the cab and obviously the horns to it’s own button. I have it so the horns can be used when the trick is off (my preference).
Lyle Longboat
6” Fabtech lift, 3” Daystar BL and 37/13.50/20 AMP mud attacks on 20x12.5 Moto Metal rims. Plus 2” Supreme Suspension wheel spacers.9C6A3194-62C1-4D54-B0E5-FCC1578FCB12.jpeg FE4F07DB-A294-4624-A5CD-73C560CE167A.jpeg 71BF6ADA-94B8-495B-B3DF-42C7F2B66898.jpeg
I still want to see a picture of your truck ... with that 9" lift ... I am at 7" right now and I am thinking of installing the 3" PA body lift soon ...
RedSRT4Me
Scottsdale, Az
2015 CC Sport
6” Fabtech lift, 3” Daystar BL and 37/13.50/20 AMP mud attacks on 20x12.5 Moto Metal rims. Plus 2” Supreme Suspension wheel spacers.View attachment 214233 View attachment 214234 View attachment 214235
I saw the brackets on the rear of the truck wondering what it was for in a different pic. Thank you for the info!
I'll have to look into finding the parts in the future although I can tell you now my horns are going satin black to hide them.
Could always install one horn on each exhaust cutout :eek::D. Then reroute the exhaust to side exit.
Lyle Longboat
Are you talking about those aluminum brackets on the spare tire crossmember? If so, those are what I made to hold the air tank. Sorry I didn’t mention that if that is what you are talking about.
I was going to paint them black as well, however was in a rush to get them installed before I sent my truck out of isolation. I still may paint them as they just hanging there.
joshuaeb09
Medina County, TX
The Core 5 link is going to help significantly and I would run the hellwig on the outermost holes if you want the most flex out of the suspension. Depending on the shocks you might want to tighten it up or run it loose, easy to play with by moving the end links to a different hole. When I still had 5100's I ran them in the middle hole which rode rougher, but gave it some more control. Shocks will also be a factor in the ass end becoming unsettled if they can't adequately control axle movement over uneven terrain.
2018 2wd
TheM4rxxx
