JATJR
Maybe some of you out there can shed a little light on this subject. I have a 2018 Ram 1500 4x4 with a 3.6 L V6 engine with an 8 spd trans and 3.21 gear ratio. I have looked at many different claims of the amount this truck will tow, I got from 3900 lbs to 7500 lbs. However I do know that the larger amount is for a lower gear ratio. As many of you know this truck and engine has good power and drives well. I also have a 2000 Dodge Cummins with a 6 spd Trans for the heavier stuff. Anyway your input may help and also how much do you tow with a truck equipped with similar equipment. Thanks.
