Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Crazy good deal on motor oil!
Discussion in 'Garage' started by pajeepman, Aug 7, 2020.
  1. John Jensen
    John Jensen Senior Member
    86
    855
    840
    Mar 27, 2016
    San Diego County
    Ram Year:
    Engine:
    Ecodiesel
    Sold out in SoCal - bummer
  2. xdmshawn
    xdmshawn Junior Member
    53
    15
    May 19, 2019
    Spokane, WA
    Ram Year:
    2005
    Engine:
    Just picked up 10 quarts of full synthetic 5w30 at Costco for $29.99, not on sale. This is the Kirkland brand. When it goes on sale it's $25 for 10 qts.
  3. Skatulaki
    Skatulaki Member
    58
    38
    Nov 22, 2019
    Green Cove Springs
    Ram Year:
    2002 1500
    Engine:
    5.9 liter 360
    Question : Why is it that they are selling that 0w / 5w water? What is the Manu's reasoning ? You have to add almost 4 quarts between oil changes? So far I cannot get a viable answer, gas mileage has been the only answer, by one store. Maybe I'm too old, but i think that stuff is way too thin.
  4. tidefan1967
    tidefan1967 Senior Member Supporting Member
    53
    2,227
    3,368
    Feb 3, 2018
    Summerville, South Carolina
    Ram Year:
    Engine:
    Strictly gas mileage and nothing else. I would be running something like 5W30 or even 10W30 in an older high mileage engine for sure myself regardless of the recommendations. Back in the day we ran nothing but 10W40 in American cars and 20W50 in the Jap stuff and it worked.
  5. canadiankodiak700
    canadiankodiak700 Senior Member
    41
    624
    519
    Apr 14, 2019
    Northern Ontario, Canada
    Ram Year:
    Engine:
    3.7L Pentastar
    You do realize that 0w30 and 5w30 and 10w30 are all the same weight oil? It's all 30weight oil, exactly same viscosity, not "water". That 0w or 5w is the winter viscosity, it's the cold thickness of the oil, making it easier for your engine to start, and flows faster when cold to lubricate all posts of your engine, where at warm viscosity, it would take longer to to reach all areas. Modifiers in the oil react to temperature change, thickening when warm to make the oil a 30 weight.
    Sent from my Pixel 5 using Tapatalk
  6. Skatulaki
    Skatulaki Member
    58
    38
    Nov 22, 2019
    Green Cove Springs
    Ram Year:
    2002 1500
    Engine:
    5.9 liter 360
    Thanks for the info, no I was not aware of that, my understanding was that 10W-30 was ten weight oil with additives that gave it the same lubrication as 30w, so I presumed the same applied to 0w and 5w. If it is all the same then why bother labeling it different.
    I understand how it might be usefull in cold weather, however as I stated, I live in Florida, its hot here, and I think the stuff is too thin. Why not just pour 5 quarts of WD 40 in there. If I have to add 4 quarts in between oil changes, then why not have an oil tank next to the gas tank. As I said, I run straight 40w ZR-1 and have no issues, and I don't have to add any between oil changes.
  7. Zoe Saldana
    Zoe Saldana Member
    30
    35
    32
    Nov 12, 2020
    california
    Ram Year:
    Engine:
    6.4l
  8. canadiankodiak700
    41
    624
    519
    Apr 14, 2019
    Ram Year:
    Engine:
    3.7L Pentastar
    It's labeled different because they are different oils for different purposes. The baseline oil used is the same but the additives in the oil are what changed the properties based on temperature so why wouldn't you label it different if it does different things? You seem to think that just because you live in Florida they should make one label for all their oils, you do realize there's a whole world outside of Florida right? It might be hot in Florida, but I can guarantee it's a hell of a lot harder inside your engine at full operating temperature, so why not create an oil that works best at every possible temperature range instead of just one.
  9. Skatulaki
    Skatulaki Member
    58
    38
    Nov 22, 2019
    Green Cove Springs
    Ram Year:
    2002 1500
    Engine:
    5.9 liter 360
    Ok lets agree to disagree?
  10. canadiankodiak700
    41
    624
    519
    Apr 14, 2019
    Ram Year:
    Engine:
    3.7L Pentastar
    No
    retired likes this.
Share This Page
