Crew Cab rear seats in quad cab
kg93
AZ
I recently bought a completely interior ram rebel set. Only the rear seats are only made for crew cabs....what do you do if you have a quad cab? This.
Tools needed:
Cutoff tool
Various sockets(mostly just 18)
Air tools(not necessary but wayyy easier)
Step one-
Rip that old seat out. For me it was a bench seat. Watch your trim pieces I scratched mine every time I took it out.
Step two-
Either remove one of the brackets on your original seat and hold it up to the new brackets to get measurements or follow my measurements
Step three-
Cut off about 2 3/4" off the back end of the bracket. Don't be afraid to cut off a little more.
It should look like this when done
Step four-
Use your cutoff tool and cut from the bottom of the remain partial bolt hole. Go about an inch further down. Same width as the bolt hole. (forgot to grab a pick of that)
Step five-
If you are going from a bench seat to a 60/40 like me you will need to find the partially cut out carpet and cut it completely out. Then pull off the tape.
Step six-
The 60/40 uses the two center seat belt bolts to hold it down. You want to put the two rear bolts partially in. The way the rear bolt hole(now more like a bolt slot) It will slide right onto the bolt. Go ahead and add washers if you want to do that little mod.
Step seven-
Put all the bolts in and tighten them
Finished project:
Take aways and tips:
Get 2 more bolts for the seat. I had to go to ace hardware since my dealer did not have them in stock.
Use gloves..don't ask how i know but my hand are a little cut up now
Use proper safety glasses when using your cutoff tool...again don't ask how i know.
You will loose about 2 inches of leg room, but hey you can have rebel seats.
Feel free to ask any questions!
lonestar21
CA
2019 Ram 1500 Big Horn
Nice looking seats!
Tight fit though is that with the front seats all the way to the front?
kg93
kg93
AZ
Nice looking seats!
driver seat is in my normal driving position. I could sit in the rear seat with 3 inches in front of me. Im 5'7"
charonblk07
Calgary, Ab
F1-A forged 349ci
Looks good Kris. Just to double check, normal people can't fit in the back seat then, right? :love51:
I own a quad cab because I never put people back there, that's where the sound system goes so losing leg room wouldn't be an issue for me.
kg93
kg93
AZ
Thanks!
hahaha don't worry its not fun for normal people to fit back there still!
I somehow managed to make my amp stop working so now i need to figure that one out.
GYSOT
2014 Ram 1500
Is the back part of the back seat still pretty straight and uncomfortable like your original? Crew cab backseats are comfortable, my quad cab is not. I assume you did the front seats as well so my second question how long do you think it took to just remove the two front seats and the bench rear seat?
kg93
kg93
AZ
they might be a little more angled but they are still pretty straight and uncomfortable, just how it is.
I didn't do the fronts yet since im waiting for some mounting brackets for my center console. Removing all the seats would take 20 minutes with air tools. Just ratchets....quite awhile
PassivAggressor
I didn't realize the quad cabs had that much room. Nice mod!
crombienator
CT
2019 Ram 1500
Stupid question. Where did you get a whole new rebel interior?
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
**Bringing Back from the dead**
If you have a quad cab 60/40 split and want to just replace the upper part of the seat so you can get the pull out cup holders. Is that possible?
bruce219
ca
pentastar
I have done this also with the quad brackets,took it out after 6 months,the back of the seat is too straight,very uncomfortable and headrests have to go if you want someone to sit there as they tilt too much towards the front,I put a leather seat out of a 2012 ram laramie quad into mine after,perfect.You can actually see the angle your back would be at in photos posted.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I have the 2016 Quad cab
I am 5' 8"
The front seat headrests hit the back of my head the wrong way
So i reversed them
I heard that some of the newer head rests are adjustable & if i see a pair that are adjustable so that i can change the tilt & the poles are the correct distance apart.
I will make the change
Because i use my Ram as a working transportation business, i need to be able to see out of every window, so i took off the 3 rear seat rests.
No one ever sits in the rear seats
My Fold Flat Floor is always being used for maps, hard hats, large first aid kit, cleaning gear, safety gear, Stop/Slow Paddles, etc.
Yogee2020
New Jersey
5.7l hemi
Asking a question can u go the other way and install quad seats in a crew and use ur old crew brackets to bolt them down
austmurr
