Recently trucks been acting up it all started when I was driving down the highway and the "wait to start indicator" came on then it shut off 80 miles later so I checked the codes by cycling the key and the two codes that came up were P0237 & P0069 (I installed a map sensor less than 4k miles ago) so I kept driving it and it started smoking white when I accelerated so I Came home cleaned the map sensor and air filter and the white smoke stopped let it sit for a few days then I took it for a ride everything's good then I shut it off for about 30 mins then I start it and start driving and when I go to give it gas it doesn't accelerate after about 2 miles of it acting up it went back to normal.. Few days later I start it and a puff of white smoke comes out the exhaust at start up and it was ticking and the check engine lights on. Here's 2 videos of the truck idling .. Listen closely and You can hear the ticking. Pretty sure it's coming from the drivers side.
Video 1- http://youtu.be/OXQbY2ettGU
Video2- http://youtu.be/fg5AKCe3hP8
Let me know what y'all think would rather diagnose it myself before spending thousands at the stealership.
