@runamuck
I see you wrote your findings here.
5960 was your CAT scale weight. You say you weigh 225 and you had a half tank of gas.
You said base weight is 5615 with those numbers.
Then you saw I said base weight is with full fuel.
You make the new figure of 5656. And if you go the other way your figure would be 5735. So your figures are 41 pounds different than the door jamb.
Your door stickers say it should be 5776.
So, you had nothing else in the truck. Just you with an accurate weight of 225 lbs? 41 pounds could be a misjudge of gas...or a hitch in the rear.
And just to be sure...you have a 2019 or newer 5th Gen DT Ram 4x4?
This payload and towing stuff is very interesting to me. I have spent countless hours in conversation about it.
I am truly interested in your numbers.
