Txhemirt
You'll want Ryans/Illicits "cut" versions if you're down past 4".The easiest way I've found to install the cut versions,is to drop the diff right out.It makes getting at things that need trimming a lot easier. Doesn't hurt to run a couple weld beads on them along with the bolts,if you have access to a little mig welder.Plan on close to a day to install the brackets,they do take a bit of work to get installed.
man i miss my drop. looks good.
i dont miss that cruise ship swaying from the lower control arm geometry lol. if you don't have them already, get some LCA brackets
Most likely will be going with illicit brackets over Inez. I spoke with illicit and they told me the brackets have been reinforced. Seen a set of the Inez start splitting but from what I understand they have reinforced theirs as well.
