Cutting Belltech 2/4 drop springs
Jtouch81
Cartersville,GA
I've seen a few threads where guys are saying that they have cut their belltech springs. I would love to go a little lower with mine but I'm unsure on where or how much to cut to get more of a 3/5 drop. Post pics if you have done it and what did you do to get it there.
WhiteNBlackRam
Southern California
I’m interested in how many coils people cut for a 5” drop in the rear. I been different things. I don’t want to remove the coils 4 times to get it right or cut too much.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Unfortunately every application is going to be a little different, but for every inch of drop on a coil spring(linear rate) you’ll cut half the measured free height. It’s not that simple with the geometry because you’re not keeping the track bar and control arms at the same angles(unless all adjustable) so they fight back.
You can always cut more, little difficult to put back...
hdoggie24
Huntington Beach CA
Following this thread. I'm lowered 2/4 but want to trim the coils too to bring down another inch to 3/5. I have the no cut relocation brackets but haven't installed them yet. Want to do everything at one time. With new shocks too
gbark80
Georgia
To get to 3 inches in the front, I measured 7 1/2 inches around the outside of the coil and marked. I have cut one coil off in the rear and am just at 4 inches in the rear. I cut my coils last June and measured against a stock truck at work last week. I'm planning on cutting one more coil this weekend on the rear. 20190615_160402.jpg20191126_073222.jpg 20191027_151734.jpg
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
How does that ride on the rough pavement Cheech?
Jtouch81
Jtouch81
Cartersville,GA
To get to 3 inches in the front, I measured 7 1/2 inches around the outside of the coil and marked. I have cut one coil off in the rear and am just at 4 inches in the rear. I cut my coils last June and measured against a stock truck at work last week. I'm planning on cutting one more coil this weekend on the rear. View attachment 198633View attachment 198634 View attachment 198635
Thanks for the reply! I'll probably do the same with the rear as well. Just to get it a little more level with the front end..
gbark80
Georgia
It rides pretty well actually. I have only had a problem at one intersection and that was cuz I caught a light at speed and the air dam rubbed really hard.
gbark80
Georgia
I cut one more coil on the rear Friday after work. Here is what it looks like now. Really happy with it.
20200321_192337.jpg 20200321_192351.jpg 20200321_193818.jpg 20200321_193832.jpg 20200321_193854.jpg
gbark80
Georgia
What's the ride quality like?
It's ok, I did bottom out in the rear on a pretty harsh speed bump. Do need to order some different bump stops for the rear, hopefully can get around to that this weekend.
Syke001
Do I need the no cut relocation brackets for the 2/4 cut to 3/5 drop
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
Have you cut the rear bump stop cups off the frame already ? On my RT, i did that and bolted replacement bump stops directly to the frame. It gave me about another inch
