- Jan 17, 2016
- 23,670
- 54,354
- 14 Sport
- 5.7
Are you planning on leaving the CV's out,if so you can also unbolt the front diff and front driveshaft and save another roughly 80lbs off the front end.My 4x4 hasn't had anything ahead of the transfer case for 10 years,and pulling everything was good for about 3/10 to 4/10's at the track.All told the CV's /front diff and front driveshaft are roughly 120 lbs,with 40 lbs of that being rotating CV weight.The old school rule of thumb is every pound of rotating weight = roughly 4 lbs of static weight,so removing 40lbs of rotating axle weight is similiar to removing roughly 160 lbs of static weight off the truckThank you all for your time and answers. One other thing I was wondering; if the cv's are removed will that open up the suspension in the front more? Give more travel?
It's not rocket science if you look at how it goes together.
